Greetings!
So I recently added some SportsMachines 20" wheels and Nitto 555R in 295/40 to my 99 Lightning. Between the new wheels and a set of Hellwig sway bars, the truck really handles nicely. However, the stance is still a little high with a good three inches between the tire and wheels well lip. I'm thinking the lower the CG, the better, and I *do* like to go around corners and make my spousal unit reach for the holy shit handle.
My truck's suspension is stock, save for the new sway bars and Belltech shackles in the back (2" drop). Front coils are stock.
Back in the day, I would have run off and installed a set of Eibach pro-kit progressive springs on all four corners, and in fact did that on my Cobra. A couple of issues: I guess Eibach doesn't make coil springs for the Lightning (might not be the right choice anyway), and I don't fully understand Leaf Springs.
My high-level thought is a 1.5-2.0 drop coil springs (H&R? Belltech?) on the front, and replace the hangers on the back. I see kits that offer the whole package, but I really just need the hangers and coil springs, because I already have the shackles.
So I notice Belltech sells a hangers-only kit (6418) for roughly $150. The add says 2" drop. What would the drop be when paired with 2" drop on the shackles that came on the truck?
I also see that they sell front coils (#23804) that talk about a 2" drop with included spacers, or 3" drop without the spacers.
I'm not looking for a "raked" look, but even drop all the way around. I've never seen the truck with stock shackles, so I just want to make sure I get the even ride height I'm looking for.
Truck is my grocery getter, but I drive somewhat aggressively around corners, on/off-ramps. I've also made a few runs at the local 1/8th mile strip.
My biggest concern, is rubbing tires, a noisy ride, and being nose-high or rear-high.
I do understand that I can drop the front with spindles, but that's pretty expensive and more work than slapping some lower coils in. All that aside, I'm looking to my fellow Lightning owners here to share experience!
Thanks!!
jc
Thanks!!
jc
