Loud pop while turning
2.2K views 17 replies 15 participants last post by  josenagg
#1 · (Edited)
Clunk washers have been done and stops greased. Still makes a clunk. Lightninmikes heard it. Something must be binding up. I can feel it a little too its on the drivers side.:smt102 p.s.Truck has full Hotchkis suspension.
#2 ·
you need clunk washers, its a normal and common problem
#3 ·
already stated that clunk washers were done
#9 ·
just an fyi, I had the same problem after lowering my L so I tightened the control arm bolts to 150ftlbs and it never came back. It's worth a shot and doesn't cost you anuthing It's been like 8 months since
#14 ·
or a front sway bar that is binding up
#15 ·
mine is doing this too, but only if I turn the wheel almost all the way to the left....??
#17 ·
hey man going through the same problems right now... going to install clunk washers this weekend and see if i can find anything else loose, if i find the problem ill let you know... its deff pissing me off!
#18 ·
had a customer at work. he had a Harley ford with drop spindles, he installed his own ball joints. he had aloud poping while turning .the lower control arm was worn,the ball joint would pivot while turning and pop .to ck this , the suspension must be fully loaded, best way to check this is on drive on lift or alignment lift .
