another E4OD question...
1 reading
736 views 3 replies 3 participants last post by  86lxcoupe
#1 ·
After a lot of searching on here I've got a question for the experts.
First things first. '95 L 150K miles, all stock. Bought back in July and drove 800 miles from Austin, TX to Nashville, TN. On the trip the trans would shift fine in stop and go traffic but after extended highway speeds it would down-shift hard and up-shift extremely hard with more rpm's to get it to shift.
The speedo doesn't bounce at all, and no check engine or ABS light.
I've reset the tps and it seemed to help with stop & go city driving. However it still will act up and shift hard after extended highway speeds or when I put push it hard. It goes away after a few cycles of normal driving without having to reset the computer. Could this be the MLPS? This is my first L so i'm not sure exactly how these trucks feel stock. I suspect the trans has been out at some point... the pan has some scrapes like it was drug out at least once, but no documentation to prove. BTW, the fluid is very clean and doesn't smell burnt.
Any suggestions appreciated. :smt023
#3 ·
It might be the TRS (Transmission Range Sensor). $100 at the dealer. There's another name for it too I think. My '94 L did something similar to that at 93k. It would shift late and slam hard into the next gear. Usually did it at slower speeds, not so much on the highway.
Basically you take the old harness and rewire it to a newer upgraded one. It fits on the shift linkage on the drivers side of the tranny. Easy job.
You could also ask the Punisher. He could tell you.
