I have checked for vacuum leaks, changed IAC as old one failed, set TPS via SCT, cleaned MAF, Short term fuel trim shows +1% regularly.
Issue I'm still having is the truck literally will accelerate on its own when I let off the brake. It will keep speeding up to approx 20km hr unless the brake is applied to slow truck. It is noticeably worse once vehicle warms up.
Have read accufab throttle bodies have some issues but I havent removed it and cleaned it yet.
I'm likely just going to get JJ to look at my tune and hopefully keep me from guessing what the issue is.
Anyone have any suggestions or values I should concentrate on while data logging?
I'm going to toss a vacuum gauge on it again later today just to confirm thats not an issue.
Does a base idle reset require re tuning? I havent done a base idle reset since putting the IAC / TPS on.
Just looking for feedback / things to check before hand so I can hopefully not waste JJ's time when I reach out to him.
Dusten has already mentioned to me that the Idle Decay may need adjusting in the tune but thats were JJ would come in.
Other than that truck runs great and pulls hard.
