Evap Issue
158 views 8 replies 3 participants last post by  TexasShriner
#1 ·
I recently purchased my Lightning and it has a P0455 EVAP System Leak Detected popping up, but it is not triggering the check engine light. I can’t get it inspected so I started investigating the cause and I found that the hose form the EVAP valve to the upper plenum has been removed and a plug has been installed on the upper plenum and the EVAP port is open (not capped or plugged). I do not know why the hose was removed or which path is the best to take so I plan to remove the plug and reattach the hose, but I need to figure out what part I need to buy to thread into the plenum that has the nipple I need to connect the hose.
Any advice would be much appreciated.
#5 ·
Thanks!
I was able to get the plug out. Going to see if the parts store has a barbed fitting that has the sage threads.
if that doesn’t work I will put a T in on the Brahe booster line as you mentioned.
I am scratching my head on why they plugged the plenum and removed the hose grin EVAP in the first place.
