Most everything has been posted to Facebook but figured I'd list here too.
DMP built engine, as a long block. Team breed valve covers to Canton oil pan.
Approximately 24k miles. Was over $11k build sheet new. $7k
3.4 Whipple with ARracetech monster inlet, throttle body, filter, remote IAC, 3.75 and 4" pulley $4k
Lightly ported 01+ lower intake turkey pan. $600
Blacktop .5" mid plate spacer $100
Set of 8 oem coils with under 1500 miles. $175
PSP long tube headers, catless mids, bassani SS cat back $900 (can split headers and cat back if buyers are set for both)
Magnum powers idler bracket with OEM pulleys and tensioner $350
Flex a lite fans kit with lightning IC reservoir bracket and controller $350
Alternator OEM it worked but was dirty and old $50
Oil cooler mount and brick $50.
Power steering pump old but worked $25
OEM engine harness from 2002 $250
I'm sure I'll have some odds and ends too as things go. If you're looking for something let me know everything is out for a gt500 swap. Photos available of any
