broke heater
773 views 7 replies 4 participants last post by  1fastmofo
#1 ·
can someone tell me what to check on my harley 03 crew cab truck. i can only feel cold air coming out when the truck is running and yes it has engine temperature. thanks
#3 ·
blend door actuator not opening up for heat sounds like.
Could need a new Climate Control Unit
check the vac lines behind the battery on the fenderwell, there is a vacuum cannister there that provides vacuum to the blend doors.
#5 ·
our system on the Harleys is vacuum controlled and electronic we dont have cables like the Ls
#6 ·
Perhaps Heater-Core or T-Stat, if the T-Stat you will/would see a temp jump. However do not trust stock temp gauges. They R crap..........
#8 ·
come to think of it...I remember an issue when building this truck...this should be interesting trying to explain.
I swapped cabs, my donor cab was a 02 and I left the heater box in it. when I put the dash in from the harley the plug that goes in by the blower motor was different. the 02 had a plug that came out of the heater box that went to an adapter then went into the harness.
the harley dash plugged in but i had to remove the adapter from the 02 all seemed to plug in fine and all my functions work on my ac but I have no heater. I also can not seem to figure out how to get it to blow on just your face unless its on the vent option which seems to not be ac...
