Need a little help here. I need to get a signal from the A/C switch to signal my elec. fan to turn on when A/C is on. Where is the best place to tap into for this? Where is the A/C switch located?
I'm picking my brain but I installed my Flex-A-Lite fans more than seven years ago and for the life of me I dont recall how my fans receive the AC signal.
I recommend tracing the wires back from the AC compressor to the wiring harness, then use a test light to verify which one is the switch source.
I was hoping somebody would know so I wouldn't have to do that, the compressor is buried pretty good and not that easy to access and trace wires. But, if I can't get an answer thats what I'll have to do.
See the descriptions for pins #41 (AC clutch relay, switched output) and #69 (AC clutch relay, control). Time to grab the test light to verify pin #41.
Thanks for the help guys. I found that the A/C cycling switch is located on top of the accumulator/drier. Now I'm not sure if that's the best place to get a signal or 41 or 69 in the pin out diagram. I would like the fan to run the whole time the A/C is on and not just when the compressor is cycling.
