Anyoone else found a ton of crud just filling up under there? For a garage queen, I can't believe how much is under the turkey pan. I prefer not pulling it which would make it very easy to clean but wanted to avoid. For 10" I have clean but can't get to the back reservoir area where the turkey pan plug was leaking oil.
So intercooler is very clean, but the bottom of pan had about an oz of oiler I assume from the driverside vacuum lines past the intercooler?
I'd like to find a clean dual separator and plumbing for both driverside and passenger. And recommendations?
Thanks for any info!
