Looking for factory sway bar brackets for a lightning. Not sure if all sway bars on the different trucks are 31mm. Picks attached are my old bent ones.
Sent from my SM-N975U1 using Tapatalk
11 second street truck
Moved to correct forum
James, when I replaced all the bushings on my Ranger, the brackets that came with the new bushings bolted right on in place of the existing stock parts. I used Energy Suspension components from Vato Zone. The brackets even worked for the rear bar on my Ranger, which is a Hellwig. Also, Energy Suspension has a really nice website. I'll look it up here shortly and see what I can find out.
Short is go into Auto Zone with a bushing in hand. Buy the bushing kit for that size bushing. It will come with brackets that will likely bolt right on.
He found the brackets at a nearby junkyard.
