I will have to go back and reread your previous post. I was unaware you can keep a/c and heat while relocating the solenoid stuff.
im pretty sure that i can keep everything in the cowl but for having a/c i might not have recirculate due to the harnesses running through but only fresh air. im going to go back and reread for my self since its been so long.I will have to go back and reread your previous post. I was unaware you can keep a/c and heat while relocating the solenoid stuff.
definitely. i will get more pictures put up of the frame mount tonight.hey 01svt_TLF can you post a couple pictures of how you mounted the pan hard setup to the frame? I really like that setup?
my set up is over kill but following tims page i wanted a low roll center, with bronco beater set up it would not work with my C notch and his bar has a high roll center with no adjustments. reasons why i went off the long bar bracket is because theres no more room left on my axle to fit and fab a bracket to mount my bar and it works greatNVM, I've taken a closer look and realized that your lower drive side mount is off of the traction bar brace with is indeed bolted to the axle.
Yup only down side to the site. Lots of good reads, but missing pics don’t help :/Bring the pics back!!!
