1 - 7 of 7 Posts
10 second street truck
What's coming for the winter mods or repairs?
Black truck - compete rebuild of front end, new brakes on all 4 corners. Finally upgrade my return line. Maybe a new tuner?
Red truck - search for a decent used e4od.
68 mustang - fix rear main. Possible carb swap. Install new speedo gear. Tune up.
Yes, winter mod season has begun! My brother wrapped up his stroked, big bore, whipple 4.0, Cobra heads, 2005 Mustang build so my truck in now under the knife.
185 Trick flow heads, ported, Manley valvetrain, bigger exhaust valves. Custom grind cams.
New tune!
New SFI flexplate, pretty sure my stocker is cracked.
E85 injectors & up the boost to 23
Billet forward drum and billet input shaft
Making my own version of the killer chiller with larger heat exchanger (150k btu) and adding another condenser 1/2 the size of the stocker. Removing my Afco heat exchanger. Adding dual wall insulated tank in bed.
small things for the HD but in the process of building a h/c/ nitrous ls1 240sx.
Here is my "to do" list...whether everything gets done is another story. Lol.
Install hard tonneau cover.
Install PSD bumper.
Relocate tranny cooler to sit behind/in PSD bumper. Upgrade tranny cooler.
Mini-tub bed
Install new wheel combo
Install snakebite bracket on Pickrel blower bracket.
Either go with tinted headlights or wrap my existing ones.
HID kit
Research and pull the trigger on either Viking or QA1 shocks
This year has been all about the lightning. But this winter id like to
get the front bumper repainted
Install stereo
Install alarm\remote start
Tint
Finish refinishing stock rims and get new tires
98 explorer sport
Pull motor for warranty work
Tint windows
Get it running properly and then spend some serious quality time with a buffer and detail the whole truck to get it ready to sell in the spring.
Hopefully the jeep will get a much needed selectable locker and a truss kit. Possibly a super charger kit.
It would also be nice to get the 68 chevelle to run as well.
Gonna have to see how things go.
Build short block.
Install
Prep for spring
Hurt feelings in spring
Paint interior.
Install datalogger
1 - 7 of 7 Posts
