1 - 20 of 23 Posts
"Only god can judge me."
Going Whipple 2.3 sooner then later as I know the MP will only be fun for so long. Looking for 700RWHP+. Few questions.
Will dual 255's, JDM fuel system with dual 255's, 80lb injectors, and 97 rails be enough fuel or do I need a whole rail setup?
Going to run big ratio so will heat be a huge issue as with the MP? I have a ICey tank and Killer chiller but am thinking about the Trick single pass unit.
Mr. Crossfire
The fuel system you mentioned is plenty. The 2.3 runs cooler than most kb/mp/eaton s/c
A fuel system with '97 rails, 60# injectors, twin 255 Walbros and big feed lines are what was on Robs truck that ran 9.74 and on Fast Gators that ran 9.9. I added some margin going with 80#ers and Metco rails. But the rails were to support tapping for spray, and the injectors for headroom down the road.
Any time you want to run big ratios you must deal with heat. It is slightly better than the MP. And better than the big bore blowers. But compressing air takes horsepower and makes heat.
Mr. Crossfire
Thanks guys. I have not been able to drive my truck for two weeks waiting on my JDM tune and all I was able to do is read LR and convince myself I need a whipple lol.
I never road in a truck with MP but I can tell ya the lil 2.3 kicks @ss
What kind of temps are you seeing with the MP and what cooling mods do you have?
With it being 80*, my IAT2s flutter around 120-125 while cruising and climb up to 140s while idling for some time.
This is with a True Forged Large IC tank, Fluidyne HE, and distilled water.purple ice mix.
I have the TF Tank and Killer Chiller. Running a 2.7 and 10. I see from 115-140. The Killer Chiller helps recover after a WOT pull. Without it temps can rise up to 170+ if you try back to back WOT pulls.
Mr. Crossfire
either way with a blower in the summer the air charge temps will be complete bs.
Boost Freak!!!!!!!!
I was running out of fuel at 700 HP with 2 walbro pumps#60 injectors, -8 feed line and Metco rails. I added a third pump and #80 injectors.
Discussion Starter · #19 ·
That's what I run but would get 80 lb injectors. I have 60s but need more fuel with the 8 lb lower and 2.75 upper. Look at my dyno numbers.
Your Post is what made my mind up. Its been two weeks since I have been at the track and looks like I am going to miss another night waiting on tune:( But I will definitely PM you when I am going to PRP
1 - 20 of 23 Posts
