9681 - 9700 of 9715 Posts
11 second street truck
Took it in for an alignment. Needs adjustable uppers. It never fucking ends.
Reactions: blacklaser94
As the trucks finally at it's permanent ride height and mostly aligned I decided to set the pinion angle. It's -1.5* now with preload set on my stifflers bars. I had to install a 3* shim.
Took a few under carriage pics
541058
541059
541060
Installed my replacement northstar battery. Wired up my battery tender. Sent eric a few idle datalogs on e85
Reactions: P_Franko03
Loaded up the final revision of my e85 tune.
Put the truck on the lift and fixed my exhaust rattle.
Gapped an ls powered gmc with big drag radials bad enough he wouldn't look at me after.
Slevin
Got the stripped dipstick bolt hole tapped and replaced the bolt for it.
Adjusted the long bars and noticed that I need to have my exhaust modified because one pipe just barely touches without any weight in it.
Trying to get the power steering res relocation on.
Edit, got it on.
541140
541181
541182
541183
541184
541185
541186
New power steering res.
Removed the airbox.
New pulley bridge.
New led fog lights
Looks good. Why did you take off the air box? Doesnt it help negate some of the under hood heat?
We'll see. At cruise I was at or near ambient. I doubt it'll be any different. And it was a fucking eye sore.
Lol. Yeah, i can see how it wld be. Looks better without. You sld paint match(or just a gloss black) your radiator cover. I think it wld finish out ur engine bay nicely👍👍
That's not an "airbox", it's simply a heat shield. And Dusten is correct, looks much better without it. I don't know about anyone else's, but my filter has never gotten that hot to begin with. So why keep ugly?
It's a heat shield that with my hood doesn't even seal against the hood.
Reactions: cbxer55
@jblot is on here and he makes them.
He doesn't make the reservoir. He makes brackets to locate the stock reservoir to the studs on the front of the motor. The Reservoir is a Summit item, obviously. It says so right on the part.
I sell the reservoir powdercoated with brackets
