1 - 10 of 10 Posts
TURBO!
I need to get an air fuel fixed. Running lean with mhs head swap. Didn't change anything for more hp but after the first pull I wish the tuner had more time.
Only difference from last Dyno are heads a springs. Patriots to mhs heads. Hot as hell today. 98 outside and humidity was high. Land and sea Dyno.
iPhone sucks for uploading images. Need with 588hp on 18psi 12* of timing. Race tuning coming with 20* and 25psi.
Mr. Crossfire
Not bad at all bud, whats your fuel system like?
Should be a monster when you get it dialed in.
TURBO!
Not to shabby for just starting to tip into the boost and low timing.
With a 8:1 compression motor, I'm happy with the number on a hot day. 25psi and it should wake up.
I picked up 88hpand 110tq with the head and spring swap. Remember I'm still on stock pi cams!
TURBO!
Aborted run at 3900rpm. After each run the hp and tq were falling about 10hp/15tq..I'm sure it was the heat. This run would have been awesome if he stayed in it. However, the 11.95 a/f was getting a little lean.
1 - 10 of 10 Posts
