Back up for sale is uncle franks 2002 TB. 41,000 miles on body 2 owner truck alway garaged. Has a JDM built Aluminum motor JDM ported heads low lift cams motor has less then 150 miles on it. Easy $15,000 to build that motor. polished Whipple 2.3 Kooks headers JDM catback exhaust. Fresh BTS transmission with PI converter with under 150 miles on it that’s $5,000. Long bars true trac QA1 shocks fiberglass leafs battery under truck joe Gambino Cut down gas tank. 60lb injectors with pumps stock fuel lines. JDM electric fan. Joe Gambino roll bar with swing outs. Bogarts Aerospace front brakes. JDM modified rear brakes to fit 15” rims. JDM build the truck from scratch. Ok the bad its really not bad. Frank has stock seats that have to go in. Truck has a race fuel tune only. Front bumper needs repaint he hit the trailer he has lower lower billet grill. Has cold AC you would need to tap the top of block to add 2 fittings for heat so you have to pull blower. Truck is ready to race he’s been 10.0 before the brakes it’s a high 9s truck the way it sits tons of good parts
