1 - 20 of 53 Posts
Well we recently began working on a 2007 Mustang GT 4.6L 3V that we had previously installed a set of Comp Cams NSR Cams, Livernois Valve Springs, HP Single 67mm Turbo kit, and a PI 3000 Stall Converter for a complete build.
Tyler decided to flex his penial muscle one night while attending the street races in Orlando and adjusted his boost controller at least 3 times which lead to his stock block grenading @ approx 150MPH!!! Luckily nobody was hurt he kept it on the road and aside from the engine managed to keep the car in tact. Which is amazing because when it arrived at the shop the entire car was covered in a 1/4" thick coating of oil.
Plans for the build:
RP Racing Engines 4.6L Longblock
Crower Crank, Crower H-Beam Rods, CP Pistons, RP CNC'd 3V Cylinder Heads w/ oversized stainless valves, RP Spec Turbo grind camshafts w/ Manley dual valve springs, Clevite HP Bearings, ARP Everything, FRPP Billet HV Oil Pump.
ATF Built Stage 4 4R70W Trans conversion
Complete Fore Precision Triple Pump Return Style Fuel System utilizing 3 Walbro GSS342 Fuel Pumps, supporting hardware, & 105lb/hr injector dynamics injectors
RP Eliminator custom Single Turbo kit w/ Bullseye 82mm Billet "Batmowheel" Turbo
AMS 1000 Boost Controller
JPC Sheetmetal Intake Manifold
and a whole lot more...
Carnage Pics!!!
Aside from the stub of the rod that let go there was only 1 recognizable piece of piston left, a 2" piece of rod, and of course the only thing to stay completely intact was the wrist pin!
Discussion Starter #2
Some pics of the new engine assembled on the stand and awaiting some parts from the powdercoater to drop back in...
Discussion Starter #4
New pics of Tyler's RP Modular Racing Engine coming together... She'll run even better than she looks!!!
P.S. Valve Cover is just a mock up for what's coming... Going to take a slightly different Approach!!!
Discussion Starter #7
Engine is back at home while we make some final fitment modifications to the intake and then off to ATF for the Stage 4 4R70W install then back to RP for final assembly!
Awesome!!!!!!!!
very nice
Discussion Starter #11
Engine is home... Finishing up a few minor things then off to ATF for the Transmission so we can get Robert's baby finished up!!!
Nice new Bullet Engine Mounts
Fore Fuel Hat Assembled and ready for install!
:bigtu
tuned by JJ @ WMS
that engine screams sex!!!
Great job and good looking engine,by the way, where did u get the water pump pullie?????.Good luck :smt023.Joe[smilie=3g
Discussion Starter #17
More updated pics of final intake fitment and hidden fpr installation...
@ Joe Raptor... That's actually a coated Steeda Waterpump pulley from their under drive kit.
Discussion Starter #18
Up close pic of the "stealth" fuel pressure regulator install!!! Fully adjustable and easy to get to yet unseen for a clean install and less clutter!
Discussion Starter #19
Can't believe it's been so long since I've updated this thread... Well the build has changed direction several times and we are finally about ready to fire her up. Original plan was to re-use his existing HP Performance Turbo kit, but we realized the piping just wasn't up to par for the power we want to make as well as a few other minor things that changed along the way... Let's get updated shall we...
Discussion Starter #20
New turbo kit is done and off to the coaters! Hoping to have this badboy running inside of two weeks!
Chris welding away...
Weight reduction!!!
Coldside...
Hotside...
New 60mm Wastegate dwarfing the old 38mm unit...
1 - 20 of 53 Posts
