They are working good on my motor!
Remember when I said I took one of the first sets to L&M engines? Michael took them apart and said everything that is supplied will work just fine for most applications. Of course upgrading those items would help if you have something that would require it but by no means is what TF supplies junk.Take a pair to a high end machine shop. See if they'd be willing to run them with the installed hardware.
I know my machine shop said "trick flow should be embarrassed for selling these"
And.... In my almost 40 years of being in the automotive industry I can tell you one thing about most "machine shops" and that is what do you honestly think they are going to tell you Dustin? Take them a set of heads that really dont need upgrading which makes them no money or "Oh hell yeah, you need to upgrade this junk" so they make some money... Think about it and also think about the numbers I posted and the logical conclusions you come to when you think about most of these failures...
If I've sold and installed that many sets of heads, how many sets do you think Summit or Trickflow have sold total? And if that number is in the thousands then were is the "absolute junk" threads and opinions from the hundreds or thousands of broken valves, valve guides etc...????? I dont see it, but what I do see is a set of heads from time to time that someone installs, installs wrong and/or installs the wrong cams and then blames it on trickflow. Thats the majority of these failures.
I wont name names but I can tell you for certain three "failures" posted on this site are directly attributed to installation error and wrong cams.
[email protected]
So he said he liked the castings and the design but you had better pay me to upgrade the other junk correct? You know the other "junk" that has served the majority of the users with no issues.I didn't took mine in for upgrades to fix damage. So he wasn't selling me anything.
He said the castings were great and he liked the design.
And l&m saying it should work for most applications sounds like a line of shit.
I've yet to see you prove a single failure I've listed was cams or install issues.
You're putting words in his mouth.So he said he liked the castings and the design but you had better pay me to upgrade the other junk correct? You know the other "junk" that has served the majority of the users with no issues.
Personally I chose to trust the guy that checked the valve train geometry and came to the conclusion that you should have a specific cam for these heads to get the most out of them. Mike at L&M is head and shoulders over most others in his field and he is the single reason why specific cams are on the market for these heads. Others may pass off what Mike did as their own knowledge but they are not the ones that came up with it to begin with so yeah if Mike at L&M says the parts used are good for the majority of applications I trust him and I did trust him time and time again with no parts failures in any of the builds I have done here in house. From Lightning and Harleys making mid 500's to high 700's, from Eaton to 3.4 Whipple trucks, from 4.6 N/A Mustangs to pro charged built 4.6 Mustangs... Every single one are straight out of the box installed with ZERO issues.
Lastly if you want me to prove a failure due to camshaft or installation error thats easy...
The one you or someone else listed here with the picture of the cracked valve guide... Installation error or too big of a cam for certain. A valve guide only breaks and cracks if the valve is allowed to move side to side. A valve guide by definition is a "GUIDE" not a moving part that can crack. That valve was moving side to side most likely because of valve spring bind. Or the cam was too big and it "rocked" the valve tip when the valve was wide open, spring bound up with nowhere to go..
And yes they are powder metal guides but guess what, so are stock PI head guides and I've never seen one crack because you can run a big 619 lift cam in them without valve spring bind.
Speaking of valve spring bind.....
A set of cams were sold on the market place about 2 years ago... They were listed as brand new spec'd by someone who people get cams from quite often... They were listed as "Trickflow specific" cams for these vehicles...And they were sold.. BTW turns out they were 619 lift..
I get a call two weeks later. The purchaser installed them, destroyed his heads and asked for my advice on why he had a failure and intially blamed the heads After talking to him and him telling me the 619 spec I told him the guy that sold you the cams is who he needs to speak with... The well known cam seller gave him his money back, had the cams shipped back to him and resold them but this time not advertised as trickflow specific. He also left the guy hanging to get his heads fixed and whatever else damage occured.
And again, I dont want to name names but I can read between the lines, look at pictures and logically come to a conclusion, especially when the person has very limited knowledge on how to install the heads and cams and then has a failure... Most people do not have the correct tool for installing the follower after the cam has been installed. "Popping them in" with a screwdriver is not correct.
As I have said and I will repeat again, there have been failures that are directly related to the product itself. I'm not saying Trickflow is immune to that, I'm just saying that if they were using "junk" in thousands and thousands of cylinder heads that they produce and sell, along with the hundreds of sets that I have sold and personally installed you would think you would see larger numbers of failures, but you dont.
And as I said in my opening post "This thread is meant to show my personal experience with the cylinder heads. There are plenty of other opinions and threads about others experiences with these heads, this is mine and my shops experience and its true to form with no elaboration or covering up of anything.. " If you want to bash Trickflow please do so elsewhere because from my personal experience, which is vast and comes from a knowledgeable reputable shop Trickflow sells a quality product that works and works well.
The numbers dont lie
[email protected]
Its not the springs that dont allow high lift cams like that. You cant just toss a bigger spring in that will allow for anything over .580 at the valve.There was (someone) that spec cams with over 600 lift ..springs that come with the trick flow heads will go into coil bind before that.
