2000 lightning-
So I picked up some 44's with 150lbs spring upgrade, for the lightning.
cams- stage 3 blower grind, 236/243 .550 / 540, 110/120CL, 115 LSA, these cams had MPH degree service.
put them on, and installed twin 255 pumps i had on the shelf for a few years new in box.
checked key on fuel pressure, and idle fuel pressure, all good.
Long tubes, no cats, and just an 18" collector extension..... no other exhaust installed, so its Loud as Fk trying to datalog. =)
JJ is tuning it and this thing is being a pain in the ass honestly. stock lower pulley and i think its a 2.9 or 3.0 upper.
Start up idle AF is 14.5-15.0 back and forth.
70mph OD off, about the same AF than roll into boost and it will only go to 12.8-13.2 at 5-6 lbs, and climb a big if I go up in boost. Wierd thing is, when i star to roll into boost, it seems to want to go lean, than starts to richen up just not enough.
Im about out of ideas, STFT/s are .95-1.05 while normal drive.
