1 - 4 of 4 Posts
Have a 2003 Lightning with 62,000 miles with a transmission front seal that leaks. Changed to Amsoil synthetic at 30,000 miles and wonder if the synthetic could be the problem?
Head of R&D at A1 Transmission
May not be the cause but it wasn't needed. Run the cheapest trans fluid you can find in these transmissions.
Front seal isn't a big deal to change aside from pulling the trans out (3-4 hour job) but there may be another issue since the seals aren't usually prone to leak.
What would be the recommended service for a transmission with 62K miles and a front seal leak? Are there other items that should be repaired / replaced in addition to fixing the front seal?
Don't know if it was a coincidence but the rear end had to be rebuilt with 57,000 miles using Amsoil synthetic (changed at 6,000 miles), and yes I used the additive.
1 - 4 of 4 Posts
