1 - 4 of 4 Posts
where can i get a tool for removing the caged pulley . ive got a lfp one to go on
2002 Harley Davidson F-150
You talking about the pulley on the blower? LFP sells a puller specifically for that pulley. Kenne Bell sells there own version also. If you're talking about the crank pulley, you can get the puller for that one at any local parts store.
If you need to pull the caged pulley to change the accesories belt all you need to do is put a wrench on the torque converter to stop the engine from spinning then use a 12 or 14mm allen key and break it loose...it spins off. I think it is left had threaded. I did it on jack stands from under the truck. Just use the long breaker bar with a cheater bar on it. I had to put the jack stands on cinder blocks to get more height but have since then bought taller jackstands(recomended). GL
1 - 4 of 4 Posts
