Status
Not open for further replies.
1 - 1 of 1 Posts
Here are the time for the Fastest and Slowest L's
NAME/CLASS/RANK------Rect / 60FT / 330 / 1/8 / MPH / 1000 / 1/4 / MPH-----MODS
8 SECOND CLUB
1 9 Second Gen 1-------.730 / 1.227 / 3.551 / 5.470 / 127.67 / 7.093 / 8.574 / 155.02--------**,Tubbed Front-Halfed & Back-Halfed , 12 Point Cage w/ Funny Car Loop 9' Ford Rear w/ Strange 389 Pro Gears , Hoosier Drag Slicks 33x16.5 S, 4-Link , Fiberglass Front-End, Fiberglass Doors , Sheetmetal Bed Cover, 8 Gallon Fuel Cell , Wheelie Bars, Drag Chute, Aluminum Wing, Ford 351 SVO Block, Canfield Aluminum Racing Heads, Built 383ci. Ford Windsor, Hogan Sheetmetal Intake, 96# Injectors, Turbonetics (T-91) Big Thumper Turbo, Spearco Air-Water Intercooler, Aluminum AFCO Radiator, Accell Gen VII DFI., Chassis Shop #1 (Final Round Race Cars) Old Bridge Twp, NJ., Chassis Shop #2 (The Race Car Factory) Palm City, FL., Truck Scaled by (A&W Performance) Levittown, PA. , Tuned by Job Spetter Jr. (Turbo People) Hastings, NY.
9 SECOND CLUB
1
10 SECOND CLUB
1 [email protected] ------.123 / 1.483 / 000 / 6.742 / 101.17 / 000 / 10.594 / 127.38-----F, L(8), U(2.7), T W, D, S, E, A, K, V, I, H, B, O, R, J, Z
2 chillfactor------.110/ 1.619 / 4.460/ 6.845/ 102.42/ 8.932/ 10.713/ 125.03------??????
3 fomocofan -.030/ .1505/ 4.433/ 6.890/ 99.780/ 9.044/  10.875/ 122.630-A, B, C, D, E, EF, EW, F, G, H, HP, I, K, L(8), LL, M, O, P, R, S, T, TB, U (2.75), V, W
4 DonsBolt----000/ .000/ .000/ .000/ .000/ .000/ 10.90/ 122-------??????
5 03LightningRocks-----.019 / 1.621 / .4.565 / 7.016/ 100.20/ 9.153/ 10.961/ 124.58-----HP,F,H,I,L(6),U(2.5)(total of both is 19 lbs),T,W,D,S,E,A,M,K,V,B,O,X,Z
6 RAMAIRSVT ---.391/ .1684/ 4.570/ 7.015/ 99.68/ 9.156/ 10.977/ 123.51-----FTVB,A,B,C,D,E,F,H,HP,K,L10,U2.75,M,MS,O,P,R,S,T,TB,V,W
7
8
9
10
11 SECOND CLUB
1 Rob_02Lightning------.549 / 4.841 / 7.520 / 9.843 / 91.56 / 11.861 / 113.98-----FTVB,F, C, L(4), U(2), Q, T, PB, MS, N(75), 2" Drop shackles, D, TB
2
3
4
5
6
7
8
9
10
12 SECOND CLUB
1  TSDuke------.6599/ 1.8117/ 5.1159/ 7.8869/ 88.10/ 10.2980/ None/ 12.3309/ 111.19-----FTVB,A,B,D,E,F,J,K(3.5" pulley),L8,T,TB,W
2  UNDRPSI ---.645/ 1.761/ 5.109 / 7.899/ 87.59/ 10.334/ 12.399/ 108.57-----FTVB, C, D, E, F, L #4, S 1100lbs F spring 2" R shackles, Pan Bar, Hellwig sway bars, QA-1's, TB,W
3  wydopnthrtl------.732/ 1.745/ 5.123/ 7.922/ 87.23/ 10.357/ 12.402/ 112.52----C, I, V, Q, L4, E, EW, LL, O, S, TB
4  Lightninquick-----.000/ .000/ .000 / .000/ .000/ .000/ 12.5/ 107.8---?????
5  SLOWSVT95---.083/ 1.809/ 5.258/ 8.136/ 85.75/ 10.617/ 12.709/ 105.14---?????
6  RhinoHD ------.853/ 1.926/ 5.425/ 8.287/ 85.43/ 10.780/ 12.884/ 107.27----J F E L6
7
8
9
10
13 SECOND CLUB
1 Avalanche------.078 / 1.828/ 5.341/ 8.278/ 83.44/ 10.850/ 13.023/ 104.18-----F, I, J, L5, Q, PT, V, X, P, E, D
2 [email protected] mph --------Stock
3 lightningkid ----.303 / 2.078 / 330 / 5.617 / 8.502 / 85.15 / 10.999 / 13.113 / 106.47---------- F, E
4 Boss Hoss ----.774 / 1.926 / 5.598 / 8.614 / 81.95 / 11.220 / 13.430 / 102.14---2003 Harley, L6, CAI, J
5
6
7
8
9
10
Mods Legend:
FTVB= Factory Tech Valve Body
A=Headers
B=Bottom End Work
C=Chip
D=Drag Tire
E=Muffler/Catback Exhaust
EF= Electric Fan
EW= Electric Water Pump
F=Filter/ Cold Air Intake
G=Gears
H=Heads/Cams Work
HP=SCT, Predator
I=Upper Intake Work
J=Microtuner/Predator/Reflash/SCT
K=Blower Kenne Bell
L**=Lower Pulley (Size)
LL= Line Lock
M=MAF
MS= Multi Spark Ignition
N=Nitrous Oxide (Shot Size)
O=Race Fuel
P=Power Cooler
PB = Plasma Booster
PT= Ported Throttle Body
Q = Ported Eaton (any version)
R=Weight Reduction
S=Suspension
SK= Shift Kit
T=Throttle Body
TB =Traction Bars
U**=Upper Pulley (Size)
V=Conveter
W=Water Pump/Electric Fan
X = Transmission ( I.e. Monster Box, Level 10. etc)
Z=Aftermarket Supercharger (other than Eaton or KB)
Y= Homemade mod (Explain)
** = Everything that 9 Second Gen 1 has.
* Note each person will have two entries at most this is for compairison purposes.
1 - 1 of 1 Posts
Status
