I always wanted to do an oil analysis and since I am planning on pushing the stock block a bit I wanted to make sure things were in check. How many of you all do this? Posted are my results.
The built block has been running great for about 25k miles so far. I would rather not know the exact details. haha :shitstormretarded
Pretty cool info though.
My friend owns an oil change shop similar to Jiffy Lube and has oil analysis done whenever a customer comes in "claiming" his oil change blew their motor..
Im suprised you guys didnt know about this. I am just glad to see no fuel and anitfreeze is in the oil, looks like the gaskets are in good shape. Time to push it.......lol
Most Local CAT dealers and truck stops will do these in house. I do these all the time at work. I did one on my Powerstroke when I bought it used.
The customers that I have that do them very frequently seem to be worry warts.
In a piece of expensive machinery or high performance race engine I could understand for personal use I dunno. I wouldn't want to know if something was starting to fail. I just check the oil manually.
-If Scilicate comes up your getting some sand/dirt in the engine....look for air inlet leaks
-If potassium comes up coolant is getting in the oil.
-If fuel is evident there is an internal leak (diesel).
-Tin/Copper...**** it I'm driving it, it not worth ripping the pan off now
-Iron/Chromium... ditto
For personal use. The way I see it. If shits gonna break its gonna break.
If I knew any traces of contaminants were in my oil I'd bite my nails and rip the oil pan off looking to find the problem. If I went that far I'd mine as well go all out. :rockon_ford
It is pretty neat tho....I would like to know how they "sniff" everything out of the oil.
I wonder if theres a place to get this done locally in socal. I've been meaning to get mine checked out, I really have a suspicion that something is not quite right with my motor, and I can't figure it out. Maybe something like this would give me a more solid answer of "yes something isn't right" or "no, everything is fine you're just imagining things".
It seems to run fine when you get on the go pedal, but at idle I'm not so sure sometimes.
Hey gang,
Just installed:
2" Beltech Lowering Hangers, 2' Beltech Lowering Shackles, and 6 degree Pinion Shims on an '04 Lightning with stock leafs. I'm getting a slight vibration with low pitch humming (wah-wah-wah) form 15-20mph (loudest @20mpg). The pinion angle now sits at 0 degrees (the...
So Sunday Uncle Frank and I will be extending the 2019 race season 1 more week at Atco. I will try to lower the 2.6 KB record of 9.60 even further and UF will attempt to lower the 2.3 Whipple record of 9.53. Seeing the DA will be between -1,700 and -1,900 all day we will have a good shot. A...
I just wanted to let everyone know I purchased Stifflers new tubular transmission cross member for our trucks. I will keep everyone posted on it but I also wanted people know to know about it because of my T56 magnum swap. Brian and I talked there is actually a set of holes on the frame slightly...
Hi I’m building a 99 lightning and need some help with a few things. Where does this ground go?Where does this vac box go?Whats this and where does it go?
I appreciate any and all help thanks
Would anyone be interested in a small group buy of Trick Intercoolers?
I spoke with them and they can do 900 shipped if 5 or more a purchased. Saves about 50 bucks they are regularly 925 plus shipping. If you do not need adapter plate and run one of JCs plates that are designed for trick...
