1 - 9 of 9 Posts
Can you guess what this means?
Rob you keep your mouth shut lets see if anyone can guess!!!
You get a prize, what it is I do not know. :D The heads are getting ready to be CNC ported and polished and they are getting .565 lift cams installed.
I win a prize! I win a prize!! Congrat's on the mod's in progress! :smt023
Do you know what stage cam they are??
This stage stuff reminds me of the 3/4 cam (LOL). When I was quite younger I went to a local builder and told him I wanted a 5/8 cam because I thought the 3/4 cam was too big with .750" lift, figured .625 would be better!!! He was kind and informed me of what a 3/4 cam was!! Ended up with a 335hp corvette cam with .458" lift, sounded really good and performed well with my other mod's.
Bryan
Yea here is the specs on the cams that I am getting.
They are Crower
62802-2 Stage 2
Designed specifically for supercharger applications for street use.
RPM range: 1500 to 6500+ on 4.6L, 5.4L will be lower. 262 Lobe 262
276 Valve 276 216 Lobe 216      234 Valve 234     .581 / .581
I am also looking at the following cams how about some input from the power makers.
62802-2 Stage 2
276 Valve 276   216 Lobe 216  234 Valve 234   .581 / .581    More than likely these are going in BUT!!!
62803-2 Stage 3
Street/Strip profile. Emphasis on top end power. Spring required.
RPM range: 1750 to 6750+ on 4.6L, 5.4L will be lower. 266 Lobe 270
280 Valve 280    220 Lobe 224   238 Valve 242   .590 / .601
62804-2 Stage 3
Designed specifically for supercharger applications for street/strip use.
RPM range: 1500 to 6500+ on 4.6L, 5.4L will be lower. 274 Lobe 274
288 Valve 288    228 Lobe 228   246 Valve 246   .612 / .612  I really WANT these but I am not sure about the streetabliity of them.
62805-2 Stage 4
Race grind. ECU mods and tuning required. Rough idle is common.
RPM range: 2250 to 7250+ on 4.6L, 5.4L will be lower. 274 Lobe 278
288 Valve 292   228 Lobe 232   246 Valve 250   .612 / .621
Do I still have to keep my mouth shut  :smt017
:D
SMOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOKING
GO GET UM BRENT
1 - 9 of 9 Posts
