1 - 8 of 8 Posts
I have searched high and low for a brake kit for our trucks and FINALLY found this TCE Kit. Has anyone installed one, says you have to use the supplied spacer and are very tight on 18" wheels. ANYONE INSTALLED THIS? ANY ISSUES?
FRONT KITS- 2G TRUCKS
Call today to place your order or for more info! 480-967-7901
Plus 1: The 14" Front Kit
Wilwood Aero6 differential bore calipers (6 piston calipers)
Choice of BLACK or RED powder coat finish
TCE spec radial mounting brackets
14" x 1.25" directional cast rotors
Gas slotted
TCE spec billet aluminum rotor hats
Custom hubs with M14 studs
New bearings and seals
Wilwood BP20 pads
Stainless steel hose kit
All required hardware
Optional cross drilled rotor finish- ADD $150
Optional .125" wheel spacers- ADD $20
Application: Building upon our success with the older 13" front kits: Today TCE takes it to a whole new level. Now offering the full 14" Aero6 kit -- which is the most ideal kit we can produce. Massive caliper sizing and 'full size' rotors assure buyers of repeated and sure footed stopping power....time and time again.
Fit: Stock and 18" or larger wheels. Stock '99 wheels require use of optional .125" wheel spacer plate.
Notes: Our most ideal kit for open track use where pad options, and durability are a top priority. Sold only in M14 Stud configuration.
AntiSocial
THere are multiple kits out there. Baer makes a 6 piston, Brembo makes a 4 pot and an 8 pot. There may be others.
11 second street truck
What 8 pot does brembo make for these?
The Baer kit is like 3400
The brembos are 4 piston and 4300
Tons of guys have the tce kit. You'll only find good reviews. I'm ordering the 15" kit soon.
AntiSocial
I don't feel the additional 2 pistons is worth the 2200 in cost over the tce 15" 6 pot kit
Lethal sells it too
BagsR4groceries eBay built
1 - 8 of 8 Posts
