How far do you guys think I can push the stock MAF with a MAFIA on a 5inch tube? I was told around 800rwhp. Any inputs?
Well stock MAF with the MAFIA. I understand the MAFIA can take it pretty far. Just wondering. I won't be increasing the boost or anything just adding a custom plenum and 170mm TB with a 5 inch intake.You would have to log it and see. I have a hard time believing you could get that out of a stock maf even in a 5" tube. I'm running a 4.5" tube and with my ba2800 I see maf counts in the low 900s.
You are going to see more flow with the 170mm tb. I always wondered if resolution suffered down low when using an extender. Maybe others who have more experience tuning with them will chime in.Well stock MAF with the MAFIA. I understand the MAFIA can take it pretty far. Just wondering. I won't be increasing the boost or anything just adding a custom plenum and 170mm TB with a 5 inch intake.
Yes, the resolution will be affected negatively with an extender. But it also would suffer with a "bigger" Maf. Also in a 5" tube the stock type Maf is going to be a questionable choice. Slot style would be a much better choice in a tube that big.You are going to see more flow with the 170mm tb. I always wondered if resolution suffered down low when using an extender. Maybe others who have more experience tuning with them will chime in.
a mafia will take you as far as you want to go, just needs to be tuned
Where did you find that maf flange?What do guys mean by suffering down low? What's the max count on a MAF?
Also this is what would be welded on.
You can get them on eBay. $25.00Where did you find that maf flange?
look into upgrading to a slot style and run a gt500 maf..
i run a regular mustang gt maf in a 4inch pipe and needed a mafia..
sinister made 997 hp with a stock maf element in a 5" tube with an 88mm turbo.
what they mean bad resolution down low, is that the maf may have trouble accurately measuring the volume of air in a low flow situation like part throttle, low rpms.
i have a ba2800 in a 4" tube. i was using a ba2400 with a mafia, until the mafia died on me. some people have had good luck with extenders, i did not.
I made 820/875 with a stock maf with a MAFia on #2 in a 4.5" tube. A MAFia will support whatever range you want to throw at itHow far do you guys think I can push the stock MAF with a MAFIA on a 5inch tube? I was told around 800rwhp. Any inputs?
I don't see how a MAFia will have any different resolution than an aftermarket meter. The PCM can only see a set range (1024 counts?) So whether it's a MAFia rescaling what the meter is seeing, or a meter itself doing the rescaling, you're at what you're at.You are going to see more flow with the 170mm tb. I always wondered if resolution suffered down low when using an extender. Maybe others who have more experience tuning with them will chime in.
