1 - 12 of 12 Posts
Eaton Rebuilding Procedures​
The unit is fully disassembled and all parts checked for wear, the case is thoroughly inspected for rotor rub.
Front drive is completely disassembled. The shaft is checked for straightness, all bearings and seals are replaced.
Front drive coupler is inspected for wear and replaced if necessary.
Front rotor drive plate bearings - Measured for wear and replaced if necessary.
Rotors are then phased to corrected position and assembled.
Rotors are inspected for point wear and flaking, if your rotors are black they are Teflon coated, the wear on these are not accessible to flaking. If you have painted rotors that are gray and flaking we recommend stripping the rotors which eliminates any chance of further damage done from deteriorating finish.
The supercharger case is completely inspected for rotor rub. The rub is from contact of the rotor during rotation. This is always evident and more prominent if rotor speeds were increased from smaller pulleys. These areas are marked for added clearance and machined to eliminate all rubbing. In addition to obvious wear issues, contact of rotors on a case will cause heat build up.
Rear case bearings are inspected and greased and replaced if needed.
All parts are high pressured washed at temp of 190 degrees for 30 minutes to ensure all components are absolutely clean.
Reassembly then takes place ensuring all bearing press and tolerances are triple checked and torque set to factory specifications.
Supercharger oil is added and all other lubricants are fully synthetic and Hi heat tolerant.
The outside of your supercharger case is inspected for paint imperfections and touched up if needed.
The by-pass valve is installed and calibrated for correct boost-charge and climb.
If your valve is broken we can most often fix these at a small cost - replacements are available.
At time of rebuilding we can install a optional size pulley for increased boost we have many sizes available.
Porting your supercharger is an option that will increase the efficiency of your blower, adds boost in many cases, and lowers inlet air temps.
Porting the blower also increases your HP. The exact amount of power gain is based on many factors. Some of the more important factors are your engine displacement, pulley size, headers/exhaust combination, ignition and plugs and the quality of your tune. For example, a properly tuned 03' Cobra with a reasonable choice of exhaust and pulley could improve as much as 50+ HP. However this same car with, improperly tuned or with poorly-matched parts, may only gain half the HP. Basically the quality and combination of modifications will either amplify the effect of the ported blower or tend to mute it's effect.
Also, please keep in mind that not all engines are equal. A Mini-Cooper motor simply does not have the capacity of air flow that a Cobra motor has. For instance, if you start with 150 HP and gain of 15 HP from your ported blower, that is the same percentage gain as a 400 HP engine gaining 40 HP.
(we can not guarantee if ported or worked on by someone other than us)
Thank You!
Stiegemeier Porting Service,LLC
Authorized Eaton Remanufacturer
GOT BOOST!
Wish KB offered this service.
You don't happen to wrk on them huh. Hint hint
so your saying my black rotors cant flake, but if they were gray they would?
So is this an advertisement that is stuck up on a bunch of forums or what? Where is the message from the vendor to tell us why this is up, otherwise I kinda feel like this is spam really. nothing against Steig, they have great products, but I've always been a bit frustrated with vendors that throw stuff on here and then never look at the post again. Maybe this isn't the case here so I'll apologize if its not.
Even Then I Was Old Skool!
Obviously a generic "advertisement" that covers cobras and mini coopers. Would be more impressed if they actually included before/after pictures of a Lightning's Eaton at each stage described,
Mike
Discussion Starter · #9 ·
We get several calls and emails daily about our Rebuilding and we wanted to share with the internet community our process.
We have very low prices
Package deal is:
Porting Supercharger
Stripping Rotors
Front Drive Rebuild
all for $525.00
Porting Tb and Pl $85.00
Porting Supercharger only $395.00
Front Drive Rebuild only $395.00
The gray rotors flake, the black ones are different abradable coating.
Thanks and please feel free to ask us questions.
You can visit our web site click on the green box for data, customer testimonies, tests, and more.
Spam or not, I subscribed to this thread so the info would be in 1 place. Besides I think this might should go in the how to section as a checklist for the do it yourselfers.
Besides #2, I happen to like SPAM, it got me through hard times and may have to rely on it again the way things are going.
Now that Bob added his comments (thank you Bob) I now don't consider it spam. Like I said, just want a little personal attention.
Discussion Starter · #12 ·
Thanks we do try to keep up with our posts it does get hard sometimes with the phones ringing, answering emails, testing, dynoing, welding,dealing with walk in customers and sticking to our 1-3 day turnaround.
We are trying to stay on top of the internet posts, we have Don now who is helping out with it so we will strive to answer any and all questions from the Lightning community! As always feel free to call or email too.
Thanks again
Stiegemeier
636-949-2275
[email protected]
www.stiegemeier.com
1 - 12 of 12 Posts
