My truck has been apart so long that I forgot where a wire went.
There are 4 wires to the starter area.
The far left wire is a ground that goes on a starter mounting bolt with a nut.
The second from left goes to the small stud on the solenoid for the key start signal.
The third wire goes to the large battery power terminal on the solenoid.
The far right wire is too long to go to the solenoid, or is it? Or is it a block ground. As there is a threaded pad above the pan rail.
It tests as a ground, but I am reluctant to connect it without knowing for certain.
Help....Miz
Help....Miz
