I just blew spark plug #7 no check engine light. So I did the cal van insert replacement. I remove the intake to do the job. Everything went well I don’t think I could have done that cylinder good without taking the whole intake setup off. Went to start up truck , started right up and throttle up and runs good . Took it for test drive and at half to full throttle it is sputtering. No check engine light. Check all vacuum line and are good and right. The truck is completely stock . What do you think??
