1 - 8 of 8 Posts
I am going to install NGK TR-6 gapped at .037. I have a 4# Lower, SCtuner and exhaust...
This is what I usually go by for gap...
Stock boost to +2 - .038-.042
+3 to +4 psi- .036-.038
+5 to +6 psi- .032-.036
more than +6psi- .028-.032
Found this on a F150online thread.
ngk tr6's only because i run nitrous with the gap set at 34 . if your not on nitrous the hotter standard plug will get you more power . tune a little richer and not too much timing.
ken
I'm on Denso IT-22's gapped at .038 - .040
Works Flawless on many diff set ups I run
4lbs
6lbs
4 w/juice
6 with juice
Now times it by 2, since I run those set ups on both programs
TR6's are great in most cases and the usual choice for most, but I happen to rather run colder plugs, and BR7's do give some people street driving issues
Thundergod, TR5IX are the same heat range as the stock plugs, be careful as I fried two of thm on my HD last year...I just installed the TR6's today, gapped at .038.
I was pleased to see that all the stock plugs had the same gap at .044 and didn't look too bad...w/4# lower and SCT.
TR-5IX's here, but I am still running stock pulleys. I am upgrading to the TR-6IX's this weekend while my L is in pieces in the garage.
Started getting the telltale spark plug tick so thought I would change them, then decided it was easier to change with the supercharger off so I could clean my intercooler...BLAH
RhinoHD, good information on the plug gapping, that is a handy range remember.
Lightning Mike, those look to be OK, I think the AR-103's are the equivalent of the TR-6 if I remember correctly. Running rich isn't necessarily a bad thing unless you are too rich, then you are more likely to foul a plug and lose HP. Best bet is to dyno it after you install all the goodies, then you can check the A/F and dial it in.
Happy Modding,
Charlie
1 - 8 of 8 Posts
