Sorry on the poor discription, but also to Throw in some more info when going on the freeway and I Am on it shifts quickly into 4th, and acts the same I'll try to get some video on it!Is it possible the truck shifted into OD and it's not downshifting right away? Or, it could be a miss. Sometimes a miss will show up when a load is placed on the truck at lower speeds. You need to elaborate a little more on "shudder". Does it do it at higher rpms as well?
Faulty DPFE sensors cause a shudder under certain low load conditions.
What about a dirty or faulty egr valve? I had similar symptoms on my old 94 lightning. I capped the vacuum line running to the egr valve and no more shutter. Ran smooth again. Do u get a check engine light?
No.Wouldn't it throw a CEL ON?
This is kind of important information to include in your original post since the issue could be related to the servicing. Double check all vacuum lines, etc....new plugs last week cleaned TB cleaned MAF new air filter new oil change Tranny fluid looks good
No.
Worth noting since I mentioned the DPFE sensor previously... the DPFE sensor has an electrical connection and high and low references from the EGR tube. If you cross the high/low references for the DPFE it will not operate properly.
Pull the reference lines off the DPFE sensor and the EGR tube. You'll notice that one line is a larger ID than the other. Look at the ports on the DPFE and the EGR tube and you'll notice one port is larger than the other. Make sure the rubber lines are installed so the larger line goes on the big ports and the smaller ID line goes on the smaller ports.
Converter lock-up is normal, but I wouldn't exactly describe it as a studder. Also, converter lock-up would have been present since the day you started driving the truck. Is this the case or is your studder a recent development. To me converter lock-up feels like the trans has shifted into another gear... a little bump and the RPMs settle a bit.
Yeah sorry for the piss poor description on this,but yes this has been around for awhile but I guess now that I drive more on streets I see it, kicks into next gear quickly, is there a fix for this
Yeah Its still a tune Virgin nobody has touched itEither have your tuner adjust your converter lock up speed or drive with your OD off until you get to a higher speed.
