1 - 13 of 13 Posts
The Orginal GATOR said:
That is indeed a nice setup, but I have already ordered a sweetheart setup from my favorite vendor :D
Me too
Now he has to come out with something new
the next week _($^#)@#$^@)$^@)$%)@[email protected]$
Terry shared this photo and more with me earlier when he first put it on,
sounds and looks like a very nice piece, and Terry wasn't going to talk
about it untill he did some real world testing (WHICH HE DID),
I know He was VERY HAPPY WITH THE RESULTS.
Way yo go Terry / SFPH :smt023 :smt023
Thanks guy's......... [smilie=3gears.gif]
El duderino
does it only come with the one idler pulley,
Yes, it comes with the pulley and the necessary hardware to install, including installation instructions. Check it out here:
El duderino
let me rephrase,
so it does not come with a new idler for the passenger side?
Yes, Pulley on Idler Unit only. All other Idlers will be a separate cost each.
Seems like it would put undue stress on the Supercharger pulley being so close :smt064 but then again who am I
You know something, that was my first initial impression when I took it out of the box and installed it onto my Red Lightning, but while installing it and using the correct belt in the apllication, I still have between 3/8" to 1/2" travel on the factory Tensioner, to keep the added stress off the Supercharger Snout/Thrust Bearing & Seal in the housing from getting premature wear over time. This Idler Kit is the best mod I have added to my lightning, with running a 2 lb. DUB Upper Pulley Unit and a Fixed 4 lb. lower Crank Pulley combo , in picking up 1/2 lb. boost more, over what I had before. Hope this helps, as I do believe this is the best Preventative Maintenance you can do for your Lightning, with Upper & Lower Pulleys replaced for added performance.
:smt033
This is my setup and I have not had any problems.
Discussion Starter · #13 ·
That setup will work nicely to! :smt023
1 - 13 of 13 Posts
