Ok guys been awhile since I’ve posted. My truck is running ok with the engine that replaced my 10 second motor.
I say OK because my current engine has some nasty blowby and isn’t as fast as previous engine.
The part I need help with is with the PCV system. I’ve always had my valve covers connected to a catch Can and vent to atom. Well with this current engine and it’s blowby, I get all that smoke consisting of oil/fuel vapor coming out the cans…
my question is…
1. Can I connect the driver side valve cover to closed catch can (non vented can) then to my plenum port (whipple 2.9L) instead of the intake air tube post throttle body?
2. Can I just vent the passenger side valve cover? No smoking coming out from there. It does have a PCV valve. OR do I need to also plumb passenger side valve cover to whipple plenum?
3. With my current setup, when truck is ON and I open the Oil Fill cap I know have suction coming from passenger valve cover. Is that normal? When I had both valve covers vent to ATMO I did not have this suction/vacuum there.
4. Will i need a re-tune???
I know buy having the engine suck up all that shit and burn it my plenum, blower and IC will be coated with oil. Fuck it don’t matter to me anymore. I can always clean that stuff up.
Thoughts? remarks? thanks!
my question is…
