I second that question I have a lot of surface rust on my tow hitch hookup, I was going to sand it and prime and paint with rust-oleum? Or does anyone know of a better option?
Not able to do a lot of prep in these areas for por15. I'll check out those other options. Anything else on the market that works well and doesn't require much/any prep?
I 2nd POR15. I would start by removing the bed as that's rather quick and easy and do everything in the back there. Then do what you can the best u can in other places.
Por 15 will give you your most durable and rust free finish for the future
I've tried por 15 on several parts, but the prep and humidity control during application is too hard to control. I think I'm going to try a product I found on the boat forums called. Boeshield-t9. Anyone have any experience with it?
I wasn't exactly clear...sorry. It goes on like WD40, but dries to a thin, sticky, clear wax. Seems like it might attract quite a bit of road grime if under your truck.
I had mine sprayed with an undercoating when I bought it in 2003. The dirt and grime definitely sticks to the coating but it still protects. 12 years later some areas are still holding up strong but some areas on the body is starting to flake off.
