1 - 20 of 38 Posts
Tyler Woosley.
Ordered AR Baja wheels and Mickey Thompson ET Street Radial II Tires. Is it absolutely necessary to install traction bars before i hit the track with them.
I went a couple times without bars. Just got some bars installed hope to better my 60'.
I pulled 1.8 and 1.9s on 295 16 Mt drag radials.
Mr. Crossfire
You might get lucky but you might not when ya snap a drive shaft. With no drive shaft loop, get ready to spend some coin with under carriage/parts damage.
Tracks will require a driveshaft loop with sticky tires. It is senseless to run without both traction bars of some type of bar AND a loop as lots of damage can be done. Expensive damage!
Boostaholic
I've ran slicks on various trucks for yrs without traction bars
On my lightning back in 2013 I ran a set of slicks no traction bars or stall or valve body with stock shocks and was going low 1.7s
They help the truck launch better, and can save your hide from costly damage if torque and axle wrap cause a u-joint failure.
Run without them if you want, but it's your gamble. I ran short slicks for years with hotchkis leafs and no issues or axle wrap. But when power and traction get better it was scary.
Boostaholic
Saying you absolutely need traction bars just cause one has slicks is like you Saying absolutely need condoms prior to marriage
If you're worried about a ujoint failing it will fail regardless having the traction bars or not
So to OP they help but aren't necessary and ppl have been racing leaf spring vehicles for decades without traction bars
JDM ENGINEERING
Take it from someone who once broke their driveshaft, damaging the rear end housing, tail end of the transmission, and beating the shit out of the underside of the bed and fuel tank. I did that with Nitto DR's on the street...
You need traction bars.
Slowest Silver Lightning
Running a sticky tire with a loop and long bars is just irresponsible and you are taking a huge gamble of something going tragically wrong.
We all know you meant without. I agree- I would be pissed if someone broke down in the next lane and damaged my vehicle or I was injured because they didn't at least have long bars & a loop while using sticky tires.
I want to reiterate, a driveshaft loop is a must for our trucks- even for just cruising- spend the $100.
It's not necessarily a failure of the u-joint here - it's mainly a matter of the axle over-rotating and the flange bolts eating away the u-joint support to the point that they let go - seen it on more than one DS.
Bird
Boostaholic
Bird
I've been racing trucks for 15 yrs now and personally never had any failures from not having traction bars
Now I would not attempt this on a setup that makes power but in the OPs case where he isn't making any power he can get away with no bars especially on the tires he's talking about
JDM ENGINEERING
Bird
^^^^ OP Listen to Bird he is 110% right
I did break my driveshaft with only a 6lb lower, cold air and tune. I wasn't making big power, and I did it with Drag radials on the street.
This video says it all https://www.youtube.com/watch?v=z_bhnG1KKPg Now after bars https://www.youtube.com/watch?v=W8RaA1WXdMQ
Stiffler's guinea pig
I shot those videos on a February day, a side street in an industrial area and cold Nitto DR's. If I would have been on a prepped track, on a warm day, with slicks, imagine how much more that axle could have rotated.
same as maxing out the MAF, people do it, even though it's proven to be stupid
1 - 20 of 38 Posts
