1 - 6 of 6 Posts
Boost Freak!!!!!!!!
I'm getting a slight rumble at 28-30 mph.
Could this be that I droped the rear 2 inches and need to flip the shims to change the pinion angle
Boost Freak!!!!!!!!
Thanks Mike yea you feel it in the seat its not in the stering wheel so I know its not tires I only have 7,000 miles on the Lightning and tire ware is perfect
Recently dropped the rear of my Harley 2 inches. Low and behold the dreaded rumble. Did not even bother checking the angle since it was not there before the drop. Flipped the shims and problem corrected.
Boost Freak!!!!!!!!
Thanks Im going out there to do that after it cools off a little it's fricking 94 out right now :cheers:
Boost Freak!!!!!!!!
Allright Just turned the shims around and problem solved. :D (I really didn't think you had to on a 2 inch drop)
So if you have a 03 or 04 Lightning and do a 2 inch rear drop your going to have to flip the shims ( turn them around 180 degrees) :shock:
1 - 6 of 6 Posts
