I currently do tires for a living again. Oh joy.
With that said, i will be pulling my rears off and bring them to work. I will put them on the balance machine to see how many ounces they are running out. I
still get some vibration around 70 after another shop balanced them many months ago.
Those big MT's weigh 35 pounds and it's normal to be out of balance by 1 pound.
One pound equals 16 ounces. That is absurd. Mine were around 9oz without being balanced. My axle would bounce violently at around 55mph when cruising. I even did a heat cycle and had them rebalance them again but it didnt help. That was before i worked at a tire place. Now i will do it myself to make sure. I really hate the idea of anything over 6oz being put on my wheels. That's a lot of lead. But it is what it is.
All of my Dark Stars have hit on/clamp on weights. I do not trust the sticky weights. Plus i could care less about the scratches on the rear since no one sees that.
Also if you are curious if your sticky weights will get knocked off, put the wheel on the studs, then make a revolution. That will tell you. I've done many sets of racing wheels. Zero problems. We do tell owners to use duct tape over the sticky weights if they must have that.
