I was looking under my hood today and seen what I have posted below. You can see the right side pulley looks good but the left side looks like it has lost a good amount of coating/paint.
Is this normal? Is doesn’t really have any abnormal sounds, as in like a bad bearing, but if I give it some throttle it does seem to have a bit of a high pitch coming from that pulley.
You can also see the belt as well which looks to be a result of the pulley. About the only thing I have ever noticed is when WOT it seems to surge, like a possible belt slipping. Its not much, like the truck takes off, has a very slight hesitation (like if your tires had spun) and then goes again. I know that hesitation is not something with the motor.
I don’t know so that’s why I come here to ask the experts what you think…
Thanks…
Thanks…
