1 - 20 of 20 Posts
Retired Odderator
If you are talking about the studs that bolt the blower down to the lower intake then I think you may be SOL, otherwise all the other bolts can be replaced with grade 10.9 metric bolts of the same sizes.
Ford Certified Technician
I say you get something that look tits.... long as the grade is good and the length you should be good brother.
I like chrome allens personally but you can do all kinda cool stuff like anodized black or blue or what ever.
Most torque these bolts see really are on the supercharger I believe and thats only 33lbs. Good stamped rated stainless should easily hold up to low torque amounts like used on our upper intake parts. All the Stainless I have purchased so far has the load rating stamped on it. Personally I love the clean look if Allen Bolts. Thank kirst8404 for that idea. He has had his like this for a while with no issues.
I got Kirst8404 his "Josh" (from fastenal) so yes you can berry.
I've also found out I can get chrome also, but more than the s/s bolts
Food for the thought
I have got them for every spot under the hood lol
SHCS 0173307
washer mw6420000a20000
Fender washer WC6400000A20000 or 11101241, Not at work so I can't tell you which are stocked in the Hub.
I did the regular washers in the back, and fender washers on the side 30mm OD vs the regular 20mm OD
I also used an 18-8 grade, it's got more of a carbon content in them "in theory" making them stronger than a 316 grade.
other competitors that should be able to order for you would be,
Mcmaster Carr and Grainger
Edit****
Forgot the 4 rear part number
SHCS MS2600040A20000
Reactions: MPORTETR
1 - 20 of 20 Posts
