21 - 40 of 42 Posts
Even though mine is mounted to the shroud, it isn't in a much different location. Mine may be a tad higher up. I was able to use the hoses as supplied, didn't need to shorten them at all. I don't know about everyone else's, but one of mine is attached to a hard line. Wasn't sure it would be long enough. But it reached and both conformed to the new location without fanfare.
I doubt there's any efan that sticks out that far, that it would hit the reservoir on the front of the block.
Jblot was on here 5 days ago. So apparently he still checks in. I'd wait and see if he responds to this. Or try and find him on farcebook.
Here is what the left side looks like with the EGR deleted and the power steering reservoir located to a bracket on the fan shroud. Jblot's set up is better, but I didn't know about that when I did mine. If I were to redo it, I would use his set up. Mine is simply a piece of angle stock aluminum, cut to six inches with four holes in it, painted black and bolted onto the fan shroud.
Moving the reservoir also allows you to remove a bunch of heavy brackets that run down the side of the engine. But, as an aside, the throttle bracket also attaches to those, and I dind't like how much it flexed after removing them. SO I made the piece shown, that attaches to my EGR delete plate, to make the throttle cable bracket rock solid.
Hood Vehicle Motor vehicle Car Automotive design
Maybe one day, someone will clock the MAF correctly. ^^^ lol
I've already done that. It's an old picture. Someone told me about it and I set things right. Just too lazy to take another picture. LOL!! That picture was taken after I did the
MP blower swap, clean the IC, delete the EGR, move the power steering reservoir, do all SVT Tim's hoses, do new plugs, COPS and COP screws. I just somehow put it back on incorrectly.
Vehicle Car Automotive tire Hood Automotive lighting
I bought this kit but never got around to replacing the piece of sheet metal bracket I made up to mount it to the fan shroud.
I like the idea of the throttle cable bracket support. I did notice some flex. I have had my power steering reservoir relocated under the intake for awhile but I literally just rigged up some zip ties to hold it to the coolant reservoir bottom hose. Just trying to clean up the look finally.
10 second street truck
I ran a piece of aluminum to the thermostat housing.
I was thinking that the flex might prevent the throttle from opening fully. By flexing back when the cable pulls, it might not be able to open fully. Just over-thinking on my part.
21 - 40 of 42 Posts
