1 - 12 of 12 Posts
Ok I did a search on popping coming from exhaust
Few things showed up but didn't answer my question regarding my situation
Mods are as follows cai intake sct 93 tune and stock exhaust with 2 ar 25s installed waiting for my h pipe to come so its not equal on pressure. If I need to just get my h pipe or x pipe installed would that help but it also happens on deceleration just from 35 under light throttle.
Things to check
Spark plugs
Back pressure not enough?
Take the tune out and check for lean
Anything will be appreciated thanks
So no on the h pipe I did two dyno back in the day with an h pipe and an x pipe the h pipe yielded more torque and the x pipe prodcued more hp same day tests difference in da that day was 150 so there any negatives to the h pipe on a lightning
Silver Thor! Scream Eaton Scream!
check your windshield weather strips around the windshield.
I would drive and I would hear a popping, I thought was coming from under my truck, and it wa the damn weather shrip! This was for a week :/ lol
But check the weather strip just in case, cause that happened to me.
could be in the tune, there is something for that
Hmm, I thought if it runs rich, unburnt fuel gets into the exhaust pipes and the heat of the cats combusts it, causing that popping noise after it revs. Mine used to do that but I fixed it with my tuner...
Were these tests on a Lightning? I agree that the H-pipe will yield more torque but I have not heard of anybody switching to an H-pipe to get better track times in a Lightning.
BTW With a Lightning you will have all the torque you need, tires can't take it anymore ;)
1 - 12 of 12 Posts
