1 - 20 of 53 Posts
What did u guys use to plug that vacuum line?
I'm getting balls deep in my engine bay tomorrow to clear my p1074 code and an wondering what to plug that with.
Thanks
3/8 npt plug
There's a pic you've posted a few times stew that shows the elbow at the bottom of the vac hose...
Do I plug the elbow or remove the elbow and plug the intake itself?
remove the metal elbow and then plug
best part is if you have an aftermarket efan....the plug that you pulled out of the block to insert the temp sensor....just happens to be 3/8 npt :cheers
I replaced all that crap with a barbed 3/8 T and 400 psi transmission fluid rubber hose...which wont break down and dry rot like the crappy rubber elbows and T that ford uses.
1 - 20 of 53 Posts
