Can’t use water Bc it’ll frezze can green or orange 50/50?
Or you can look at what reservoir is low. Don't over think things. It's a system other than 99-00 that isn't known for leaking.Don’t use traditional green coolant in your intercooler if you’re already using it in your radiator. Use the Ford gold coolant. Reason being is if there’s a leak anywhere you can tell what it’s from from the color of the coolant.
True it's not known for leaking but these trucks are at the very least 16 years old now, and we all know with age comes issues. It's better to be prepaired for those issues then not and this way it can be easier to diagnose any issues with either cooling system.Or you can look at what reservoir is low. Don't over think things. It's a system other than 99-00 that isn't known for leaking.
I'm not a good example anyways. Mine full of water.True it's not known for leaking but these trucks are at the very least 16 years old now, and we all know with age comes issues. It's better to be prepaired for those issues then not and this way it can be easier to diagnose any issues with either cooling system.
Garage never gets down to freezing temps.I just wouldn't want it to freeze up, even while just sitting in the garage.
Even if it's single digits outside? We get those here.Garage never gets down to freezing temps.
No sir. Garage is insulated as well as the garage door itself.Even if it's single digits outside? We get those here.
Mine isn't. I live in an apartment, and the three garages I have are non-insulated. Metal doors with no insulation. I will admit they are warmer than being outside when I'm in them on a cold day. But cold none the less.No sir. Garage is insulated as well as the garage door itself.
Honestly in single digits without constant bheat I'm not sure it would matter. Especially since you don't use your garage daily.Mine isn't. I live in an apartment, and the three garages I have are non-insulated. Metal doors with no insulation. I will admit they are warmer than being outside when I'm in them on a cold day. But cold none the less.
Unless it's raining, I open it every day to put eyes on my beautiful Lightning. ;-)Honestly in single digits without constant bheat I'm not sure it would matter. Especially since you don't use your garage daily.
I think for your situation coolant is the best option. I run water but my shop stays above 40*. The heaters on a thermostat
My use I meant like warming it up to work in it, so it retains heat.Unless it's raining, I open it every day to put eyes on my beautiful Lightning. ;-)
Ahh! Take it from me! Mine at 117k miles daily driver sandbags winter tires 4 years in Minneapolis. It did really hang. Tried to get by w summer tires slush in Milwaukee stop no don't. After a bad slip n getaway over a curb my boost was instantly slapping to 11 or 12 psi just road rage. It sat outside in the snow 2 years. Mechanic says yes we can clean the blower fluid and intercooler never touched 18 years. Wrong answer. Since then it flatlined at 8psi sad clown boost no tunes major electrical problems.Can’t use water Bc it’ll frezze can green or orange 50/50?
