1 - 6 of 6 Posts
Bet you were born naked, you SLUT!
Hello.
Picked this up used and plan to install it this week. Wiring is def my weakest subject, thanks to color codes radio installs are manageable.
Details: no sound system or back up camera. Just a simple pioneer wiring to ford wiring adapter
I don't have any destructions or diagrams and have come up with a few wires without a match.
From the pioneer harness. These four
Discussion Starter #3
I think the pioneer wires can just be capped since they are not relevant to my case (I think). But what about the black w/ white stipe and orange wire from the vehicle.
shake and bake!!!!!!
Cap them all, except the lime green one
Orange wire is a dimmer wire
Black/white is a factory amp ground
Light blue is amp turn on
Purple/white is reverse gear signal input
Green is parking brake signal input, ground this with a relay opening with the key to be able to watch videos while driving
(Pm me if you need help with this)
Yellow/black is a mute wire
:bigtu
BANNED
purple/white is reverse, if I remember right. It's the trigger if your're running a backup cam. Just cap it if no cam.
Also, you can do the relay trick on the brake wire, if you wanna be able to play stuff while in motion. i.e. "for the passenger" to watch.
1 - 6 of 6 Posts
