JJ you are 100% correct about the filters
I once used a POS Fram, and my Truck tapped in the morning, found out from Sal about the spring and ball thingy inside GOOD filters have, and Fram DON'T.
Without it, your Filter drains down over night and you start the motor with no oil in the filter. I took it out the second day, looked inside a Mobile 1 and saw the check valve,
been using only Mobile 1 Filters ever since.
OK NO YELLING I KNOW I F-k up with the last oil change (@^$%*@#$%(@#$
YA I TRUSTED FORD
#R$T#(RW(R^#(R$%#(R$%(#R$%(#$R%(#%
1st oil change = Jiffy Lube [smilie=eek4.gif] :shock: [smilie=eek4.gif]
Pennzoil Fully Syn 5w30
@ 2,907
2nd oil change = ME
PZL Fully Syn 5w30
@6,123
3rd oil change = Me
Mob 1 5w30 Syn
9,416
Last oil change = Me (SWITCHED TO FORD OIL)
Motorcraft 5w20 Syn - Blend
12,004
THIS MAY HAVE BEEN MY DEATH (thin like water)
(mob 1 Filters the whole way through)
you know me, always trying new things @$*@%
[email protected]*$
SAE 5W-20 Premium Synthetic Blend Motor Oil
Introducing Motorcraft® 5W-20, the motor oil that’s better for new Ford, Lincoln and Mercury vehicles and less harmful to the environment. Designed, engineered and recommended by Ford Motor Company, it delivers performance comparable to our Motorcraft® full synthetic at both very high and very low operating temperatures and pollutes less.
Motorcraft® 5W-20 motor oil dramatically outperforms and outprotects conventional motor oils. It meets the stringent WSS-M2C153-H Ford Motor Company specification to give the balance of engine durability and performance and to maximize fuel economy while reducing emissions. Due to its low volatility, low oil consumption is maintained. What this means for the environment is a motor oil that pollutes less.
Why you should stock up
5W-20 is the wave of the future. Most Ford Motor Company 2001 model year engines have been designed to use this new oil and Ford Motor Company now recommends it for many older vehicles as well. Since not all automakers recommend 5W-20 and not all independent oil change shops stock it, now is the time to take advantage of this opportunity. With the advantages it brings, your customers are asking for it — which means they’ll come to your business. It also helps assure them of warranty compliance and may lead to longer engine life. Ford Motor Company is a leader in cleaner and more efficient cars and trucks. Your business should be a leader in helping the environment — and your customers.
Motorcraft® Quality
Motorcraft® 5W-20 is a premium motor oil blended using synthetic and mineral oil base stocks manufactured via a process called “hydrocracking”. This process rearranges the molecules, freeing them of impurities and making them more durable and resistant to breakdown. Motorcraft® 5W-20 dramatically outperforms and outprotects conventional motor oils. Specially tailored additives are included to:
- Reduce friction
- Minimize engine deposits and wear
- Protect against high temperature oxidation and low temperature thickening, rust, corrosion and foaming
SAE Grade 5W-20
API Service SJ / EC
Gravity, ºAPI 35.0
Specific Gravity, @ 60ºF (15.5ºC) 0.852
Density, lb/gal 7.10
Flash Point, COC, ºF(ºC) 365(185)
Viscosity:
cSt @ 40ºC 49
cSt @ 100ºC 8.8
Viscosity Index 161
HT/HS Viscosity, cP @ 150ºC 2.65
Pour Point, ºF(ºC) -49 (-45)
Sulfated Ash, Wt. % 0.94
Total Base Number (TBN) 7.5
ASTM Color 4.0
