1 - 4 of 4 Posts
Anyone ever deal with P0713 code?
Left my shop and within 1-2 miles od button flashed then stopped.
Shifted and ran normal all the way home.
Drove for an hour home and plugged in the sct to get the code, and i checked trans temp, it was reading 90°
It should have been reading near 150°+ driving that long, guessing temp sensor is bad?
Discussion Starter · #2 ·
String instrument accessory Bicycle part Font Auto part Fashion accessory
Just a follow up if anyone has an issue later and finds this.
I did a more datalogs and found when truck is first started in the mornings trans temp reads -165 and bounces to ambient and back to negative etc. for the first few miles, and this causes the OD button to flash, then it starts reading correctly down the road after a few miles, and holds steady. So the temp sender is definitely bad.
The bad is the sender is located in this solenoid pack and you have to replace the whole thing as a unit, sender isn't serviceable by itself
I have a used one sitting in the garage. nothing wrong with it. $50 shipped
Either way, it's going to make a big mess.
Get about 8 quarts of trans fluid and a new filter. The OE gasket is re-useable.
1 - 4 of 4 Posts
