1 - 8 of 8 Posts
El duderino
On the oil filter/coolant adapter on the drivers side of the block, which is in and which us out for the oil lines? I'm plumbing a remote oil filter adapter
Are you eliminating the oil cooler all together?...You can use a screw on adapter that screws on where the filter would normally be...It will be marked in/out, or should be...Then you can just run your out line to the remote filter and then back to the adapters in opening.
El duderino
yes. i'm going to be using an aftermarket oil cooler. i have the block adapter to hook up it up along with a remote oil filter mount and the ploy motor mounts that eliminate the factory setup.
That's the way Jerry is setup now...I got my mount off of Casey...I am just using a N/A 150 filter adapter...I am going to try running it without a cooler for now, but I have a remote filter and air cooled setup to use if temps get too high.
El duderino
ok, so which is the oil supply, top or bottom?
El duderino
i think the bottom is out and the top is in....but i'm not 100% on that without looking at my old oil cooler adapter and i don't have it here
1 - 8 of 8 Posts
