Hey guys,
I am about to replace the oil cooler on my truck, haven't pulled the filter off yet, but I assume that after I remove the oil filter, the shaft the filter screws onto is keyed, and I will need a 14mm allen key socket to remove the shaft that holds the cooler to the housing, is this correct?
And the second part of my question, what is the torque spec for tightening the shaft back on to the housing? I read somewhere 41-44ft/lbs??? I am not sure that is correct so if somebody with more knowledge could help me out, thanks.
-Adam
-Adam
