If you use the stock housing that runs along the block, you can just buy a nipple for $8.00
F1AZ-6890-A
The lower radiator hose from a N/A truck.
3L3Z-8286-BA
F1AZ-6890-A
3L3Z-8286-BA
This is what i did. U can have a local machine shop clean ur oil filter adapterIf you use the stock housing that runs along the block, you can just buy a nipple for $8.00
F1AZ-6890-A
3L3Z-8286-BA
Wanting to do the delete (had an extremely tight clearance with the oil filter on my Moroso oil pan) however if it becomes too much of a pain, I will take your advice especially at $8 plus the hose. (-:If you use the stock housing that runs along the block, you can just buy a nipple for $8.00
F1AZ-6890-A
3L3Z-8286-BA
Just took the cooler off and it looks like your idea may also solve my clearance issue.If you use the stock housing that runs along the block, you can just buy a nipple for $8.00
F1AZ-6890-A
3L3Z-8286-BA
Good afternoon friends,
Planning on doing the (Complete) Oil Cooler Delete and am not sure if I have the right part number for the Oil Filter Adapter for use without the cooler.
The part number I have is XL3Z-6881-AB which I am finding for over $300.
I am needing to confirm that this is the correct part number and ask if anyone may have or know of a source to purchase this part new.
***I can't use the oil cooler I have since it came off a blown motor.
If anyone has any other ideas, I would appreciate it.
Thanks for your help!!!
Mel
I grabbed a filter and held it all in place and came up with about the same clearance you have. Looks like we have a winner.
The part number I have is XL3Z-6881-AB which I am finding for over $300. 😲
Mel
Wouldn't you also have to replace the driver side engine mount, since the bolts run through the oil filter adaptor as well?normal “f150” ones work IF you also change the lower radiator hose
If you were removing the Oil Cooler and housing/mount you would need to change out the motor mount on that side. I only removed the cooler itself as described by Certified Drunk above.Wouldn't you also have to replace the driver side engine mount, since the bolts run through the oil filter adaptor as well?
yes, but it’s a simple bolt / unboltWouldn't you also have to replace the driver side engine mount, since the bolts run through the oil filter adaptor as well?
I just had to replace my Oil Cooler due to getting oil in coolant. Apologies but it was nowhere a simple bolt/unbolt situation. Granted I didn't have a lift but still!!yes, but it’s a simple bolt / unbolt
Looks like I’ll be doing this as well when I put my new build in. I spun 4&8 rod bearings in my old motor, it lost oil pressure and the timing chain took a chunk off my oil pump. Looked like strippers had a party in my oil pan. So I’m very hesitant to reuse my oil cooler.Here is how mine turned out just removing the cooler. Big thanks to Certified Drunk!!! View attachment 550388
