1 - 17 of 17 Posts
Can you install a oil breather cap without having to change your tune. What are the benifets over the stock sealed oil cap.
Yes but be prepared to wipe your motor after every WOT run you do...... The only benefit is if you bypassed your pcv system. Do a search on it.
If you have a fully functioning PCV system and add a breather on the filler cap you could be drawing unmetered air.
+1
I just replaced my breather that came on the truck when I bought it with a proper oil cap. I have an aftermarket oil cap on my SVT Contour so now my truck has a Contour oil cap. :) They're exactly the same though.
Mine didn't make a mess, it didn't smell. I just didn't want the motor to be pulling in unmetered air.
Johnny Law
This, you will continue to get a code (p0171, I think) I had this code come up as soon as I installed a breather, I would clear it and it came back a few days later, I removed the breather and the code never came back.
I have a CFM k&n style oil cap breather for sale. I bought 2 only used one. It's very nice, and has a baffle to prevent spillage. I've put about 150-200 miles on it so far and no sign of oil. PM me if your interested and I can give pics.
Would a breather on the passenger side be responsible for unmetered air since it is on the windage side of the motor?
Retired Odderator
L&S style oil seperator is the best solution, it filters the oil from the PCV system, keeps the system closed like it should be, and causes no mess or smells.
You get what you pay for.
1 - 17 of 17 Posts
